Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-22-2015, 11:20 AM
bmklawt bmklawt is offline
1997 ram, violent font end shake
Had upper and lower ball joints replaced a few hundred miles ago and the truck had run just fine. Just replaced the the front bearings, axle seals, left axle shaft (Spicer brand) and right U-joint. Now at highway speeds if I hit just the right bump the front of the truck will start to shake and within a few seconds the shaking is violent, almost have to come to a complete stop for shaking to stop.
Any ideas on what is causing this?
Your help is greatly appreciated,
Bruce
Bruce
2014 Toyota Camry Hibrid
2005 Silverado Z71 5.3L
1997 Grand Caravan 3.3L
1997 Dodge Ram 1500
Old 09-22-2015, 07:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1997 ram, violent font end shake
You're suffering the dreaded Death Wobble.
The steering shaft bearings and or drag link are badly worn.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
