Ash Tray Door Falls Down
My 98 PA ash tray doesn't stay up. I can't see what is wrong. I meet another PA owner that has the same thing.
Is it in the dash, or is it in the door that flaps down? What do I need to do to fix it? What part can I get/do I need if I went to a wrecking yard? Thank you, Chris.
1998 Buick Park Avenue (best car GM ever made) Buick Lesabre 1997, 191,000 152,000 - Motor R.I.P. Used 111,000 Motor, All New Gaskets Used 102,000 Transmission - SOLD New Balance 662 Trek 8000 |
Re: Ash Tray Door Falls Down
Duct tape?
I am unfamiliar with the '98. Does it withdraw or slide like a drawer or flip up/down to open and close?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
I sometimes need to get into it to charge my phone. It flips down.
Chris.
The problem is its a 17 year old car that was built somewhat cheaply. As far as interior trim goes anyway, corners were cut. You may just have to improvise, it's a Buick, not a Bentley.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!" -James May, in an old, worn out Lamborghini purchased for less than £10,000. |
happydog500--first, I use the socket on the seat front bolster.
If you remove the ash tray, you will see that a small plastic pin has been broken off. You need to look closely. The broken end of the pin may still be in the latch track, and if it is, that will give you the length for the new one. The plastic pin is part of a molded piece, and the pin runs in a slot and is captured to lock the ash tray in the up position. Remove the molded plastic part that was the pin base. Then you carefully drill a hole the same diameter as the broken pin, in the same location as the old pin. Look carefully at the base piece and you will see where the old pin was broken from the base. You will need to either find the broken pin or look closely at the base to determine the diameter of a replacment pin and the new drilled hole. If I recall, the length of the plastic broken pin was 3/8 to 1/2 inch. I made a replacement pin from a small screw with a nut to hold it in the drilled hole. I filed the threads smooth on the screw where the new metal screw pin runs in the slot, but left threads for the nut to hold the new pin in the drilled hole. Use some lock-tite on the nut and grease the pin a little. If you don't file the threads or make the pin smooth in some way, the threads will eat the plastic groove in short order and fail. Basically, you are replacing the broken plastic pin with a new metal pin made from a small screw of the proper length. Mine has been working for some years now. Good luck! |
I'll let you know how when I'm done. Thank you, Chris.
I have a solution......secure it upward, and quit smokin'!
