Old 09-21-2015, 11:40 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
door won't open from the inside
99 k1500 (older body style)
I saw older threads but didn't want to revive 11 year old threads. Door opens from the outside but not from the inside. Do I need to remove the whole interior door panel? What am I looking for? My auto parts store sells this, but it seems to require rivets (I don't have a riveter) so if I DO need this part, is there another way to install it?
This ain't your grandma's car!!
Old 09-22-2015, 06:17 AM
brcidd's Avatar
brcidd brcidd is offline
Re: door won't open from the inside
I've seen this dozens of times- front door, back doors no different. 9 times out of ten, you can remove door panel and take a large pair of pliers and bend the door latch rod so that the bend makes it "shorter" to compensate for the wear in the plastic bushings that has occurred and caused your issue. I bend the rod just enough to open the door with the latch-testing as I go-
works for another ten years- and cost $0 which is what I can afford!
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 09-22-2015, 07:57 PM
gw84's Avatar
is it pretty obvious which rod I'll be bending? Anything else I need to know?
Old 09-22-2015, 08:10 PM
brcidd's Avatar
Yeah- real obvious- the one that moves when you pull on the inside handle- and not the one the door lock switch moves.....
'99 GMC Yukon
