Old 09-14-2015, 07:42 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
90 2.2l fuel injector
im having issues with performance all over really. while the engine is cold the idle is ok but will miss and rev up and down a little. while driving it feels like theres a very slight miss. changed the map and a tune up and cleaned iac with no change. rebuilt the tbi with no change. i did notice the injector is spraying ok but while running i do see it dripping in the center of the injector. is there anyway to rebuild it?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 09-16-2015, 12:12 PM
Tech II Tech II is offline
Re: 90 2.2l fuel injector
No, you replace the injector.......could also be a PCM/ECM....
Old 11-12-2015, 11:13 AM
cousincletus cousincletus is offline
Those injectors go bad every so often (I used to get about 80K miles out of them). I would just replace with a Standard Ignition injector. They were 80 bucks last time I replaced one about 15 years ago. They would give me the same symptoms you're experiencing when they were going bad. I use Lucas fuel treatment (3 oz per 10 gal gas) and that seems to help.
