Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 09-13-2015, 10:46 PM
jbengle's Avatar
jbengle jbengle is offline
2006 Jeep Liberty P0032, 38, 52, 58
My daughter has an '06 Jeep Liberty with 210,000 miles which recently just had the engine seize up. We bought a used engine and swapped it out. Everything went pretty smooth (after a new starter and new radiator). I expected several codes once the new engine got fired up. We reset 12 codes and now the only ones that keep coming back are P0032, 38, 52 & 58 which are all 4 of the oxygen sensors. I have checked and double checked all of our plugs and harnesses. I never had to unplug any of the O2 sensors. I had to unscrew the upstream ones to get a socket on the exhaust bolts, but that is it. I replaced one of the downstream sensors with a new one but the code for that sensor did not go away. I could sure use some ideas on this one.
Half split the problem, one step at a time.
Old 09-14-2015, 01:00 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 2006 Jeep Liberty P0032, 38, 52, 58
check the fuses, there is one for the O2 heater circuit. can also check for 12v at the O2 plug
The Following User Says Thank You to Crvett69 For This Useful Post:
jbengle (09-21-2015)
Old 09-21-2015, 07:58 PM
jbengle's Avatar
Thanks for your help Crvett69. I couldn't find a fuse for that circuit like it shows for the earlier models. I did find after searching around that I missed one of the ground wires to the engine block. Once I attached that and reset the codes the problem was solved.
