Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 09-13-2015, 07:50 PM
rlanders rlanders is offline
P0171 and P0303
I have an 08 equinox with a 3.4L engine. I am getting a p0171 code and today while test driving I got a P0303 code which I am guessing is caused by the condition causing the 171 code. I know that the 171 code is referencing the egr system what I don't know is if they are typically the problem or do I need to look at something else first. I would appreciate any input.
Thanks!
rlanders
Old 09-14-2015, 06:52 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: P0171 and P0303
P0171 is a lean code for bank 1, P0303 is a misfire code for cylinder #3. Most likely you have a problem with #3 fuel injector as this would cause the lean code and misfire, or a vacuum leak at that cylinder. Probably an injector issue.
The Following User Says Thank You to gmtech1 For This Useful Post:
rlanders (09-14-2015)
Old 09-14-2015, 06:23 PM
Re: P0171 and P0303
Thanks for the info, I'll check into the injector.
Old 09-16-2015, 12:10 PM
Tech II Tech II is offline
Re: P0171 and P0303
It could be an injector....could also be a bad wire, plug, or coil(3/6)....
Old 09-17-2015, 02:05 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: P0171 and P0303
Thanks!
rlanders
Hello rlanders,
Is your Equinox currently exhibiting any concerns at this time? If so, we would be more than happy to look further into your situation for you. Just send us a private message with the following information for assistance: VIN, mileage, contact information, preferred dealership and additional details.
Have a wonderful day,
Helen
GM Customer Care
Old 10-16-2015, 09:55 AM
Re: P0171 and P0303
I have replaced the spark plugs and the pcv hose which was listed as most likely cause but I'm still getting the p0171 code. No longer getting p0303, however I did get c0561, p1779 and p0404. Any one with knowledge with these codes your advice would be appreciated.
Old 10-16-2015, 12:21 PM
gmtech1's Avatar
Re: P0171 and P0303
P1779 and C0561 are informational codes that are most likely related to the P0404. The P0404 is a sticking pintle in the EGR valve, also common on these as I have replaced many for the same C0561/P0404 combo. The P0171 could be a tough one to isolate. Be sure you are running a "top tier" fuel. Make sure there in no "unmetered air"(vacuum leaks or intake duct leak, exhaust leaks).
The Following 2 Users Say Thank You to gmtech1 For This Useful Post:
rlanders (10-19-2015)
Old 10-19-2015, 12:21 PM
Re: P0171 and P0303
The EGR valve seems to be a common probable cause for the codes I've seen I was just hesitant to replace it without knowing for sure that it was the problem. Sounds like I need to go ahead and change it. Thanks for the info.
Old 10-19-2015, 02:25 PM
j cAT j cAT is offline
Re: P0171 and P0303
this is most likely the problem. The PCV hose does not securely fit the PCV. PCV is riveted into the engine . the 90 deg rubber connector swells up then you get a vacuum leak..the hose assy can be replaced or use a new 90 deg rubber piece .. I have had failures with these on other cars they do not last very long. the EGR would cause different codes.
Old 10-19-2015, 02:58 PM
Re: P0171 and P0303
I replaced the pcv hosee with a brand new one from the dealert but that did not fix the problem.
Old 10-22-2015, 02:19 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: P0171 and P0303
I would highly recommend replacing the EGR valve. It commonly causes the P1779, P0404, and C0561 codes as previously mentioned as well as the Service Stabilitrak/Service Traction Control messages as a result of said codes. You wouldn't be seeing C0561 if you weren't seeing those Service Stabilitrak/Service Traction Control messages. It is well documented on the Chevrolet forums that replacing the EGR valve usually gets rid of these issues on the Equinox w/3.4L engine. It took care of these issues on our Equinox when I replaced the EGR valve a few years ago.
The P0171 is another story. A bad EGR valve typically doesn't cause this. I saw that the PCV hose was replaced, but also check the brake booster hose along with the fitting that screws into the intake. The MAP sensor seal should also be inspected. If everything else checks out with regard to vacuum/intake leaks and exhaust leaks then you may have a bad upstream oxygen sensor.
Before doing anything else, replace the EGR valve with a good quality replacement. I recommend using AC Delco if possible. If the P0171 code persists after a few hundred miles of driving, then replace the upstream oxygen sensor in the rear exhaust manifold.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
The Following User Says Thank You to Ruley73 For This Useful Post:
rlanders (10-22-2015)
Old 10-22-2015, 02:41 PM
Re: P0171 and P0303
I appreciate the input.I guess I'll replace the EGR valve and see what happens. I'm not sure what else to try at this point.
Thanks Again!
