Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-10-2015, 11:08 AM
Whiteram20 Whiteram20 is offline
Sudden loss of rpm
Im new to this forum and needed help. I was driving at 60mph and all of sudden rpm drop to zero went back to normal rpm after 5 seconds, pulled over thinking I blew some thing every thing seem normal is this a sensor problem. Any help would be appreciated thanks. 2000 dodge ram 1500 5.9l 2wd
Old 09-21-2015, 11:52 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Sudden loss of rpm
A momentary loss of engine speed signal, from the crankshaft position sensor imo.
If the Check Engine light is on, you can get a free diagnostic scan at most chain type auto parts stores.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-25-2015, 08:52 PM
thanks for the reply it hasn't did it since it was a little weird but will probably scan for other things as well
