Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Corsa/Barina
Old 09-07-2015, 07:07 AM
cyclon cyclon is offline
How does the distilled water flowing in the engine?
Hi.
After making a flush to the cooling system there are some quantity of tap water
that stays in the engine block.(no drain plug available).
I would like to know what will happen when i pour 2 gallons of distilled water through the upper radiator hose(while the thermostat is disconnected)?
Will the distilled water flow directly to the water pump and out to the bottom radiator hose(without passing through the cylinder head and engine block passages?
Or it will flow first through the cylinder head,after that will flow to the engine block and in the end will flow through the water pump to the radiator bottom hose(disconnected)?
Will the distilled water will push all the tap water out of the engine block or just mix with the tap water?if it doesn't,why?
Thanks in advance.
Old 09-08-2015, 04:41 AM
Re: How does the distilled water flowing in the engine?
Anyone???
Old 09-09-2015, 12:19 AM
Is this forum active
Nobody know the answer
Old 09-15-2015, 05:22 PM
MikeCStig MikeCStig is offline
If the thermostat is disconnected the flow path of the cooling system is not complete, so with no drain plug, that may have something to do with it.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 09-16-2015, 11:38 AM
Originally Posted by MikeCStig View Post
If the thermostat is disconnected the flow path of the cooling system is one complete, so with no drain plug, that may have something to do with it.
Hi.MikeCStig.
Thanks for your response.
What did you mean when you said?
Old 09-18-2015, 09:44 AM
Not complete, the the flow is NOT complete was what I meant to say... fucking autocorrect....
