Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 09-02-2015, 01:31 PM
BSracer BSracer is offline
2005 Jeep Liberty AC repair ??
My Liberty was cycling the AC compressor very quickly and not blowing cold air at idle. Seemed cold enough when driving, so I thought it needed some Freon. Went to put some in and I have a very high pressure on the suction side. Google search lead me to believe the refrigerant control valve is bad. I don't have a manual. Can some one tell me where the RCV is located or some where on the web I can see a diagram of the AC system?
Old 09-02-2015, 05:51 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 2005 Jeep Liberty AC repair ??
Did you measure that very high pressure with the bottle open? or closed? if open, yep that is the bottle pressure--cycling rapidly means very low suction pressure (without bottle near vehicle) so you have contradicted yourself otherwise.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 09-02-2015, 09:48 PM
Thank for the help. I checked with gages.
@idle suc>53 dis>270
@1500 suc>50 dis>300
@2000 suc>55 dis>350
outside temp 90F
Poor cooling, The pressures seem high. If this is correct will Freon help?
Old 09-03-2015, 12:05 AM
brcidd's Avatar
No- put a garden hose mist to front of condenser- then report back pressures- should be lots lower on both- which will prove you have a heat transfer issue at condenser- as in little air flow volume- bad fan (clutch fan?) or dirt/debris in condenser fins....since it cools well while driving, I suspect bad/inop fan(s)
report back
'99 GMC Yukon
The Following User Says Thank You to brcidd For This Useful Post:
BSracer (09-09-2015)
Old 09-03-2015, 11:57 AM
With a mist on the condenser it ran well suc>40 dis>100 +-. Washed out the condenser with pressure and the compressor keeps cycling in and out 22>46 and 140>160 with a shop fan on in front. Discharge air never got below 75F. I may be rushing things but the cycling of the compressor tells me some thing is wrong.
What is this and where does it go?
Old 09-09-2015, 11:30 AM
Thanks brcidd.
I learned how to check relays and that the fan motor was bad. Replaced the fan and now idling
Suc = 39
Dis = 170
Clutch stays engaged.
