| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
Custom 70’s Vette
This started as an MPC Street Fever Vette. A very good friend gave it to me; it was complete, unpainted and (poorly) partially assembled. It came apart with only minor damage (all repairable) to a few parts.
![]() The opening for the grill is probably the worst damage to the body, but not a real problem. The rear panel has some glue smears, but a minor issue as well. ![]() I decided to go curbside. After I cleaned up the body and cut out the “scoop” in the hood I reinforced a few spots inside the body and cemented the hood on. ![]() Next it was just a case of trueing the body, (typical ‘70s tooling), scribing in the panel lines to be more uniform and sanding off molded in details like the Corvette scripts. ![]() ![]() I plan to go with some type of metal-flake paint job. I have a few bottles of original Testors Metal Flake colors that seem appropriate. |
Re: Custom 70’s Vette
I set up the stance and ride height with wire axles and brass tubing. I intend to use the kit’s tires, but not the turbine style rims. I also want it to sit a lot lower than the way the kit builds. I had to hog out the rear chassis and inner wheel wells to make room for the tires.
I had these resin wheels I cast laying around and they have bosses for wire axles molded to them. I probably will not use these wheels, at least not without some added machined rims to make them deeper. Right now I’m leaning towards Daisy’s.
Recover it! Good luck, we looking forward to see your build.
I cast a bunch of wheels in a couple styles and offsets for a friend and I decided on the Daisy’s from those for this project. They were cast modularly (each of these are two pieces in the photo) and these would normally make 15 x 8s, but I will add another rim section to the back and make them 15 x 10s.
I decided on a green, but not the Testor’s Jade Green I had been leaning towards.
I test shot this Tamiya TS-20 over an olive green and didn’t like the coarse look of the metallic. Over yellow it looked much finer. It still needs another couple coats and I might tweak the shade to be a bit louder after I see how it looks with full coverage.
nice progress!
olly olly oxen free |
Very cool!
