Old 09-01-2015, 04:09 PM
temperingloser temperingloser is offline
99 buick park avenue window regulator
just wondering if anyone knew where I could get a front driver side window regulator I am having a problem finding one and tired of the window going up and down slow due to the window ending up on the wrong side of the rubber
Old 09-01-2015, 04:16 PM
aleekat aleekat is offline
Re: 99 buick park avenue window regulator
http://www.car-part.com/
Post back, that's what makes Forums Work.
Old 09-01-2015, 05:12 PM
tried that now and waiting on a reply
Old 10-23-2015, 02:00 PM
bronzeback5 bronzeback5 is offline
I too came here looking for a driver's side regulator. You can buy the motor everywhere, but no regulator. Tons of them on eBay, but not drivers door. I need to find the part number and see if we I can cross it to another vehicle maybe.
Old 10-23-2015, 02:37 PM
Alright, I called the local Buick dealer and he told me what I had found by looking at the parts diagram. For the drivers door it's not a regulator, they call it a lock module and its the whole shebang. $1300 from GM ha-ha... He said he had a guy in a few months ago and they gave him the bad news and never seen him again lol..
I'm gonna tear into mine, lube everything, and see if anything is loose or if I can find a fix.
Old 10-25-2015, 08:57 AM
Blue Bowtie's Avatar
Registered Offender
I've found a similar problem in other vehicles. More than once I've had to disassemble the interior door, remove the motor and regulator, and straighten, repair broken spot welds on the frame and mounting brackets, clean and lube the regulator. If the stamped gear teeth in the main lift arm are intact, the rest is probably salvageable. If the teeth are damaged, it will take a little more work.
You'll have to get out the TIG and build some more material on to shape new teeth.
Old 10-25-2015, 03:23 PM
Tech II Tech II is offline
Very rare to see the regulator go bad....that's why it's usually the motor...easy fix since it's bolted on....
Need a regulator? Boneyard....
