Old 08-31-2015, 08:53 PM
GMONLYVehicles GMONLYVehicles is offline
08 Trailblazer Intermittent AC problems
My Ac comes on normally and will work for about 30 mins, then it just shuts off and blows warm air. If I shut the motor off and restart it, it will work again. I heard it could be the Clutch coil when it get hot will shut off. I have changed a relay also.
Old 09-01-2015, 06:41 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 08 Trailblazer Intermittent AC problems
have fixed a few dozen Trailblazers and Envoys that have your exact issue- Usually on vehicles with 175,000 miles or more, the a/c compressor clutch air gap wears too wide, it can pull in when cool, but takes more magnetic pull when the system warms up- so it can't. The test is to slam the hood, or to bump front of compressor (I know, it is real tight down there) - when it is supposed to be on but isn't. If it pulls in, then the gap is too wide and a shim behind the clutch driver needs to be removed. On your vehicle, I pull the clutch fan and radiator shroud out to access, then I remove the 10mm bolt and gently pull off the clutch driver, and throw the thickest shim away and re-install everything and it fixes it for another 175,000 miles.
The Stealership will "fix" it for you by installing a new compressor- if you have an extra $800 laying around.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
