Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-30-2015, 09:18 PM
P05Crossfire P05Crossfire is offline
Smile rough idle 2008
I have a 2008 Sentra S with 73,000 miles. When I come to a stop with my foot on the brakes and in drive gear the engine idles rough at 600 rpms, but as soon as I release the brake pedal the the engine runs smooth and the rpms go to 750. If I have the A/C on the engine stumbles even worse. Could there be a vacuum leak in the power brakes system that are the cause and how can that be checked? Or any other ideas? Thanks.
Old 09-01-2015, 01:38 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: rough idle 2008
if you run the engine for a few moments then shut it off you should be able to hear a hiss if you apply the brakes with the engine off. booster should hold vacuum until you apply brakes a couple times. can also tell if its working right by pumping brakes a few times with engine off, apply the brakes then start the engine, pedal should drop a bit as the vacuum comes back
The Following User Says Thank You to Crvett69 For This Useful Post:
P05Crossfire (09-02-2015)
Old 09-02-2015, 08:38 PM
Re: rough idle 2008
I'll try that procedure this week. Thanks for the info.
