Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 08-30-2015, 02:02 PM
JJS94 JJS94 is offline
Pontiac Bonneville 400 engine for 79 Firebird
Hey guys,
I'm currently looking to find an engine to rebuild which will end up in a 79' Firebird.
I have found a 400 CI engine currently sat in a 1967 Pontiac Bonneville. It turns over but is in need of a complete rebuild. Externals appear totally stock. Is this a good choice or should i perhaps be looking at the smaller 350?
Also is there anything specific that i should be watching out for when buying? The engine has seen better days and is going for $600.
I also Understand the motor mounts are different on later models? Problem or not?
Worth it considering as I will be importing to the UK?
I have a feeling it wont be hanging around very long so a reply asap would be much appreciated : )
cheers,
Josh
Old 08-31-2015, 06:32 AM
Blue Bowtie's Avatar
Registered Offender
Re: Pontiac Bonneville 400 engine for 79 Firebird
The external dimensions of the 400 are the same as the 350 (it was only 326 CI in 1967). The Pontiac V-8s had fairly stout crankshafts with large journals, and as such were reliable. Architecture is similar to a Chevrolet V-8 from the oil pump and lubrication system to the timing drive. The intakes were all of the air gap variety and thus used a stamped steel valley pan to cover the lifter/pushrod area. Intakes are difficult to acquire compared to other engines. If the stock intake is designed for a four barrel carb it would be more desirable. It would also be best to get a complete engine with all accessories since finding accessory drives and brackets would be difficult, and even more difficult in the UK.
Engine mounts are not difficult to adapt.
https://www.yearone.com/Product/1967-81-firebird/tb389
The Following User Says Thank You to Blue Bowtie For This Useful Post:
JJS94 (08-31-2015)
Old 08-31-2015, 01:20 PM
thanks for all the info
