Old 08-28-2015, 01:00 PM
ronniegene ronniegene is offline
sluggish truck
I have a 98 f-150 with a 4.2 and my check engine light is on and when i'm traveling down the road i notice that when i give it gas the engine feels sluggish and my check eng. light is now flashing any idea's would be great ...thanks
Old 08-28-2015, 01:34 PM
aleekat aleekat is offline
Re: sluggish truck
Yes, the idea is to read the code.
Post back, that's what makes Forums Work.
The Following 2 Users Say Thank You to aleekat For This Useful Post:
ronniegene (08-28-2015)
Old 08-28-2015, 01:45 PM
Re: sluggish truck
i know what a random code flash is and how to read it the check engine light is just flashing but thank you anyway
Old 08-28-2015, 07:21 PM
Re: sluggish truck
i also noticed with this problem im having is that i'm using more gas as normal
Old 08-28-2015, 07:35 PM
liya_leacree liya_leacree is offline
Re: sluggish truck
Is the problem just found, or a regular problem for you? I bought my car in April and the engine is very strong. Several months passed, i feel it a little sluggish now. And i didnot driver happily.
Any way, hope you can find the reason and solve it soon. Good Luck.
---Liya from China
Old 08-31-2015, 08:09 AM
65comet's Avatar
65comet 65comet is offline
Re: sluggish truck
Just to let you know, I have a 98 w/4.2 also. I suggest pulling the back spark plug on the drivers side and taking a look at it. If it is fine, then you will have to catch a time when the check engine light is on to see what code is popping because it could be hundreds of things.
If the plug has a yellow coating, maybe even heavy enough to be fully loading it and shorting it out, then it is a common problem. The quick fix is to clean the plugs and do it about every other month. The EGR system is a crappy design. Instead of a large port going into the main area of the intake system, they did small individual tubes as part of the intake that lead to each cylinder. Because 6 and 5 on the drivers side are closest to the valve, they get the bulk of the exhaust gas. It coats those plugs. Also those tubes fill up with gunk that stops the free flow past the valve affecting the running, and sometimes the gunk comes out in chunks and catches in the plugs shorting them out.
Old 09-30-2015, 08:06 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: sluggish truck
A flashing check engine light is a class A misfire and should be address ASAP. Typically, driving a vehicle with this type of misfire will lead to damage and more expensive repairs if not corrected. It is common for coil packs to go bad on those vehicles. In reality, you should have the vehicle scanned to see which cylinder is causing the misfire and perform the appropriate repairs, more then likely can be fixed with a simple tune up.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
