Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 08-25-2015, 01:01 PM
Durango901 Durango901 is offline
Exclamation 2000 durango 2wd suspension issue
I recently repalced all the ball joints sway bar links and tie rod ends. i noticed it started pullun to the left real heavy. so i parked it and set the steering wheel straight and stood in front of the car and the driver side tire look like it was toed to the right(facing car). i also have outer tread wear on that same tire. can i simply adjust the tie rod end to help straighten it. and i also noticed that my ball joint screws were loose. i guess i should retighten with loctite?
