Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-21-2015, 08:17 PM
MTSpeedDemon MTSpeedDemon is offline
1996 Corolla common issues?
I'll be getting a 96 Corolla this week. I'm wondering what are common trouble spots to look for? I believe the motor mounts have been replaced and the A/C blows cold. 38MPG Hwy.
Has gasoline smell when engine running and not moving. Fuel system pressure test forward of the tank is in spec per Toyota dealer shop. Do these gas tanks have problem areas to check?
Old 08-22-2015, 12:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1996 Corolla common issues?
Check for codes in the ECM. You may have a small leak in the emissions system.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-26-2016, 09:42 PM
Keg914 Keg914 is offline
I had a small leak where the fuel line connects to the fuel lines on the engine. It ended up being the little round ring that acted like the gasket on this particular connection. This was on my 93 1.8l.
