Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-21-2015, 07:34 PM
mikey531 mikey531 is offline
Send a message via Yahoo to mikey531
2005 3/4 4X4 5-9 cummins pan leak
We had the engine rebuilt and the old pan had some rust spots nothing through but we bought a new pan. Now after a few nights of frustrating work we finally got it in and running ! But.. the pan is leaking, tried tightening but no help. I have been wondering if there is a different gasket we should have used or someway to stop it without pulling the engine or transmission?
Thanks
Old 08-28-2015, 05:57 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2005 3/4 4X4 5-9 cummins pan leak
We use Ultra Gray silicon to seal the gaskets on pans on race engines
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-28-2015, 08:08 PM
DeltaP DeltaP is offline
It's a single piece gasket, hard to screw up especially with the engine out for overhaul but sh*t happens. That's a stamped steel pan. Could it be distorted? The gasket can be changed w/ out removing the engine or trans. Not much clearance between oil pan and cross member so lifting the engine is a must. Be happy it's not a gas engine or you would be pulling the trans. I always load up extra silicone in the corners. Ultra Gray is very good but any RTV should do. Buy an OEM gasket too.
