Go Back   Automotive Forums Car Chat > Cars in General
Old 08-21-2015, 05:21 PM
Brandon505 Brandon505 is offline
compression test with warm engine
you're supposed to let an engine cool before removing spark plugs (especially with aluminum heads), so how can you do a proper compression test where you're supposed to warm the engine first?
Old 09-03-2015, 09:04 AM
Chris.howels's Avatar
Chris.howels Chris.howels is offline
Re: compression test with warm engine
There are several precaution measure, that you have to take
1. clean the spark plugs from any dirt, while the engine is cold
2. disable fuel and ignition systems before removing the sparks
3. put on some gloves to prevent getting skin burns
4. remove the sparks plugs very carefully, do not remove them if they offer resistance after turning it more than one half a turn
Old 09-04-2015, 02:25 PM
DeltaP DeltaP is offline
On a cold engine loosen the plugs 1/2 turn and blow out any dirt around them with compressed air. Snug 'em back up and warm up the engine. It doesn't have to be hot. Then remove them all with hand tools only. Disable spark and perform compression test with throttle wide open.
Unless it's a Ford Triton engine... Several of them will break anyway.
