Old 08-21-2015, 04:25 PM
nystargazer nystargazer is offline
turn signal problem
my pass side front turn signal does not work
i am not getting power to the turn signal part of the bulb
everything else works running light cornering light ect. except no power at the plug for the turn signal that plugs into light bucket assy
the arrow in the dash blinks fast as if the bulb was blown, getting power to the rear but not the front
any ideas?
thanks
Old 08-21-2015, 09:20 PM
Tech II Tech II is offline
Re: turn signal problem
Helps to know the year....
Old 08-22-2015, 10:10 AM
98 olds intrigue 3.8
Old 08-22-2015, 10:48 AM
Looks like a possible DRL's module problem......
The signal from the turn signal switch is making the lights flash in rear and I/P, so the switch is ok......however, this signal goes through the DRL's module to the turn signal bulb in the front.....
The only way to confirm this is to disconnect harness connector, C1, of the DRL module and jumper "G"(dk blue/white) to "C"(dk blue), and then try the right directional.....if it works, you need a module......if it doesn't then you have an "open" in either circuit....
You have checked the RF directional socket and connection at the socket first?
Old 08-22-2015, 01:14 PM
yes i checked the socket
can you tell me where the drl module is
there is a plug that connects to the headlight assy i am not getting power to the turn signal at this point the problem is before the headlight assy.
thanks
Old 08-25-2015, 05:48 AM
Unfortunately, I don't know where it is.....but like I said, the power to the socket comes from the DRL's module...
