Go Back   Automotive Forums Car Chat > Buick > Enclave
Old 08-19-2015, 11:22 PM
surrender surrender is offline
Question Coil replacements
Sorry this is double posted. So I've got a misfire issue caused by faulty plug/coil. Service records show that CYL 2 coil was replaced at 34,000 miles and CYL 1 was done at 77,000 miles. The Engine harness fix done at 90,000. My car is at 100,820 miles and now CYL 3 coil needs replaced along with the plug according to dealer($330). They also suggested I change the other 5 plugs (another $370) I always do plugs as sets, not individuals.
So, Here is my question...should I just replace all 6 coils as well when I do the plugs?? I can get a GREAT deal on a set of six AC DELCO online. I'm Hoping that replacing coils at same time as plugs I would eliminate any more issues with coils failing one at a time. Any extra input/advice from you all would really be appreciated.
THANKS!!
02 impala 3.4L
09 Buick Enclave CXL AWD
Old 08-20-2015, 09:04 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Coil replacements
THANKS!!
If you can get all of them at a price you like, then go for it! I don't see any reason not to.
Old 09-04-2015, 08:39 PM
When I replace the coils should I put some dielectric grease inside of just the boot or Should I also put some on the connectors for the coil packs as well?
02 impala 3.4L
Tags
coil , misfire , plugs , replacement , spark
