Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-15-2015, 07:25 PM
jleduc12 jleduc12 is offline
2004 buick regal
I have a 2004 buick regal ls I have no blower motor, cruise control, AC, or rear defroster. All the fuses are good and I've replaced the blower motor resister and still nothing. This problem was off and on through the winter but now nothing.
Old 08-15-2015, 08:03 PM
Tech II Tech II is offline
Re: 2004 buick regal
Well, usually, when a group of accessories don't work, and all the fuses are OK, sometimes they all share a common ground.....
The easiest circuit to check out, is the blower motor.......remove the harness from the motor, and with a test light, check power AND ground circuits in the harness......If you have power but no ground, and attach a redundant ground to the ground circuit of the harness...
Old 08-15-2015, 10:04 PM
I've checked the grounds and they all are good
Old 08-18-2015, 09:10 PM
You do realize that there are grounds all over the car? Under the carpet, under the the dash near the steering column, etc?
Did you check for power AND ground at the blower motor harness connector, with the key on, Hvac on, and the blower setting on various settings?
Old 08-20-2015, 08:28 PM
the power and ground are good at the resister plug and at the blower motor. Used a volt meter power wire at the resister shows over 14 volts the other wires to the different switch settings don't change 3.08 volts on all. At the blower motor plug the readings are over 14 volts with the switch on high and 3.08 on every other setting.
Old 08-20-2015, 09:01 PM
I never test for power on high current elements(motors, solenoids, etc.) with a multi meter......is shows only potential voltage, not working voltage....for example, you attach two test leads to the blower motor harness, and the meter reads 14 volts....you disconnect the meter and attach a test light to the harness...with a 14 volt reading you would expect a bright test light....but it is dim......Why? because there is a voltage drop in either the power circuit, or the ground circuit...this can be caused by high resistance from a bad connection(arcing) or rust....there is very little current(micro amps) going through the circuit, with a multi meter(very high resistance, usually 10 megohms)....with a test light, you have 2 or more amps running through the circuit, causing a voltage drop across the bad connection.....
You say you have no blower motor working, yet you show 14 volts....So if the power side is ok, and the ground side is ok, that blower should be running, unless you have a bad blower motor....
Old 08-21-2015, 07:12 AM
brcidd's Avatar
brcidd brcidd is offline
I always test motors with them plugged in-- 12.6 volts unplugged- but 0 volts when plugged in, means bad connection, burnt, corrosion etc.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-21-2015, 03:34 PM
I now have a blower motor on hi, none of the other positions work and I still don't have cruise control or AC
Old 08-21-2015, 09:56 PM
My schematics don't show a resistor block, but a blower control module.....
