Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-14-2015, 10:26 AM
tmeister184 tmeister184 is offline
AC/Heat problem
I have a 2007 PI and recently lost heat and ac. All the controls do what they are supposed to do but both heat and ac blow room temp only. Fuses and relays are all good. Is this a blend door actuator problem? This is my guess and I'm basing the next question on a yes answer. Is it possible to access the actuator by making an eightXfour hole in the top of the dash above the radio. I would prefer not to have to pull the dash out of the way since everything else works good.
Old 08-16-2015, 01:15 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: AC/Heat problem
Yes, sounds like the blend door actuator.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
The Following User Says Thank You to silicon212 For This Useful Post:
tmeister184 (08-20-2015)
