Go Back   Automotive Forums Car Chat > GMC > Commercial Trucks
Old 08-11-2015, 11:39 PM
bstrom1953 bstrom1953 is offline
95 TopKick battery drain problem
This truck just had a new alternator installed and replaced the 8 year old batteries. The alternator charges properly.
Because we previously had times when the charged batteries would go dead overnight, I checked the current to ground with the key off. The ammeter immediately read 28 ma. About 20 seconds later it dropped to 18 ma. and then finally settled at around 8 ma. Is this normal? Shouldn't the current drain be zero when the key is off? Is the computer on all the time and draws that amount?
I pulled fuses at the fuse block mounted on the firewall and found two 40 amp circuits where the current was going...around 4 ma each. FYI it has a Cat diesel engine. I'm just wondering how long two big 12 volt batteries will hold a charge with 8 mils of current going to ground.
Thanks for any ideas.
Old 08-12-2015, 10:16 AM
DeltaP DeltaP is offline
Re: 95 TopKick battery drain problem
8ma is about what the ecm will draw. That shouldn't make a dent on a pair of fully charged group 31 batts in parallel. What other accy's on the truck? Lift gate, refrigeration unit? Lift gate only being used while truck is running?
Old 08-12-2015, 10:34 AM
brcidd's Avatar
brcidd brcidd is offline
Rule of thumb is anything less than 50 ma draw is fine.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-12-2015, 11:11 AM
That's some driveway you got there.
