Old 08-07-2015, 06:13 PM
B551OP177 B551OP177 is offline
Exclamation Skyline R34 "Uras"
Hi, everybody! It is my second model after long idle time.
This whale undertook to do as he also doesn't force idle time, something to change in appearance. Color will be light gray + crimson disks, I think will well look.
Well, went. I began with a suspension bracket, prepared and grounded the bottom, rims and details of a suspension bracket.
I painted the bottom, wheels and elements of a suspension bracket with brakes. Also I collected all this and I tried on a body. After fitting it wasn't pleasant that the back of a sky is lifted too up therefore the back suspension bracket had to be underestimated. As a result Sky laid down perfectly, it is pleasant to me. Wheels still need polishing and to allocation of bolts, well and in a suspension bracket it is also necessary to work with bolts a toothpick
Thnx for watching!
Old 08-12-2015, 10:50 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Skyline R34 "Uras"
Nice progress
In Progress
Old 08-13-2015, 06:34 PM
Small progress! I established and painted an exhaust, to bank I painted. Also I made disks: I allocated bolts, I polished and I put dekal. On the bottom bolts were similarly painted.
Further I passed to salon, I grounded details, it is at the moment almost ready, remained slightly.
I make an interkuler
Old 08-16-2015, 05:43 PM
We will pass to a skуline. At last I graduated from salon
That was made. I didn't begin to bother with seats which go in a set, to grind off from them belts, etc. I found old 34 Top Secret skyline, there I was just fooled with belts and the seat normal was. Generally I painted anew a seat mat, and belts on length didn't approach Therefore it was necessary to remove etched locks and to make belts anew. I did belts of paper which goes in packs of cigarettes, simply I painted it in blue)
Further I bothered with production of hooks which will keep belts in a body, well and finally I added wires "+ and -" from the accumulator.
Here ready result
Tags
drift , nissan , r34 , skyline , uras
