Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 08-07-2015, 01:59 PM
broomds broomds is offline
Cool 1997 mirage de high idle
Ok so I have a 1997 mirage with the 1.5 M/T. it idles at around 2200 rpms all the time. I have replaced the tps, plugs, wires, cap, rotor, and checked for vacuum leaks. tested the iac resistance and it is on the high side but still in specs. I have been diagnosing this issue for about 2 months and im clueless. has anybody else had this issue that might now where to look for problems? thanks
Old 08-07-2015, 03:29 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 1997 mirage de high idle
even if its within spec i would suspect the iac, it might check ok but can be stuck in the high idle position. if you can remove it without to much hassle try taking it off and plugging the holes and see if the idle drops way down or engine dies
Old 08-07-2015, 05:04 PM
Cool Re: 1997 mirage de high idle
I can plug the port inside the throttle body cutting off the airflow through the iac and it idles at about 450
Old 08-07-2015, 08:48 PM
Update... Car is now idling at 950 rpms. It was an exhaust leak this entire time
