Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-05-2015, 09:43 PM
WhiteRodeo4x4's Avatar
WhiteRodeo4x4 WhiteRodeo4x4 is offline
Delayed heater and overhead info center
for the past two or three days I have noticed that when I star my car (2000 Impala3.8) the heater and overhead information center delay turning on. Is there a relay for this or has anyone else had a similar problem. It does eventually come on just not right away. I'm thinking a bad relay. Any information would be helpful. Thanks Also no sun roof power either .
Old 08-06-2015, 06:01 PM
Re: Delayed heater and overhead info center
someone told me that the ignition switch will do this ...I am going to search the web and try to get an answer.
Old 08-06-2015, 10:17 PM
Tech II Tech II is offline
Auto temp HVAC system?
Old 08-07-2015, 10:04 PM
Talking Re: Delayed heater and overhead info center
I took the ignition switch out of the car and disconnected the two main wire harnesses. Then I took the plastic cover off the end and noticed that there was a carbon build up on 3 of the five contact points. I took 800 Grit sandpaper and sanded the corrosion off and re assembled the pieces and BINGO the glitch stopped. ...when I put the switch on the Fan and the info center on the roof panel lights up and works great.
