Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 06-30-2003, 03:49 PM
Flying Turtle Flying Turtle is offline
fan problems
well i just finally fixed the body of my car after running it into a 18-wheeler. everythign is ok mostly force fit. but i did it... installed new radiator... and got fans and shrouds from a 92 g20... engine turns on and all but the fans wont turn on.... i started the engin... it gets a lil sluggish when lights are turned on... i bypassed the fuses to see if power was getting to the fans and yes.... it does but it drains alot of power from the car... the engine hesitates... how do i get the fans to start working.....please help me
Old 07-10-2003, 05:07 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Two things. Are you sure your fan has to be on in the first place? It's not that it spins all the time. It only turns on when the temperature is too high for the radiator to handle (especially at slow speeds or when stationary).
And also check your wiring loom. If it drains that much power, it is likely that there is a short somewhere. Or even the fan motor itself is messed up (come to think of that, this one sounds quite likely!)
good luck to you
1988 Sedan Deville inside fan problem Matt137 Deville 1 09-25-2009 10:15 PM
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 08:50 PM
1988 626 2.2 4dr auto non turbo ignition radiator fan heater fan problem gogi 626/Capella/Capella Wagon 0 07-21-2006 03:15 PM
