Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-01-2015, 01:31 PM
kennywhit kennywhit is offline
runs hot
my 2006 runs hot so I straight wired the fan what I am asking did the fan have 2 speeds and if so is ther any way you know to run it in 2 dirrent speeds as its straight wired thanks a million
Old 08-04-2015, 11:10 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: runs hot
There is a controller module on the fan itself, and it communicates with the vehicle PCM. Put a scanner / code reader on it and see if there's a code. If the fan is having an issue, you might see a P1285 code, even if the light is not on.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-14-2015, 01:09 PM
tmeister184 tmeister184 is offline
Re: runs hot
Kenny,
If you have to keep it hot wired you might want to wire it through a relay so it doesn't put a big amp load on your electrical system. I believe they use resistors to bring the high(full speed) down to low(half speed). It may be that wiring in a rheostat will allow you to set it at any speed between off and full.
The Following User Says Thank You to tmeister184 For This Useful Post:
kennywhit (08-14-2015)
Old 08-16-2015, 01:16 AM
silicon212's Avatar
Confoundingly Lucid
Re: runs hot
The fan speed is controlled via a PWM controller - not a resistor. This controls the fan speed by pulsing the power at certain intervals.
