Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 08-01-2015, 08:26 AM
gumbadon gumbadon is offline
multiple problems 1998 durango
1998 dodge durango5.2 i changed ac blower motor now fan will only run when key is on the on or access. position when istart car no blower motor, tried changng ignition switch no help,,also door locks are now not working along w/ domew lite when door opens, but will go on w lite switch, sometime blower keeps running when ignition switch is off & keys are out, then i just hit a power window button & blower motor turns off.
Old 08-01-2015, 09:22 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: multiple problems 1998 durango
I doubt the blower was designed to work when the key was in the Start position, so by not working in the Start position currently would not be a problem. Usually most of the accessories are shut off in the Start position to enable as much current as possible to be available for the starter motor.
But also the blower motor usually wouldn't work in the Accessory position, only the Run position. And since it doesn't shut off all the time when the key is turned Off, that does sound like an issue with wiring or an electronic module somewhere.
Did you change the ignition switch, or the key cylinder switch? A lot of people refer to the switch you put the ignition key in to as the ignition switch, but the ignition switch is a separate component activated by the key cylinder switch.
The issue with the door locks, dome light, and power windows sounds like either an issue where the accessory delay relay is not getting a signal that a door opened or like the Body Control Module (BCM) is malfunctioning. I know Chrysler has had a lot of issues with the BCM in the past....
-Rod
Old 08-01-2015, 11:05 AM
thnks rod don't understand why all these problems arise from changing ac blower motor..fyi the book says to take off dash etc. to change blower motor we went in thru glove opening done in 1 hour.
