Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-31-2015, 12:43 PM
corem corem is offline
Send a message via MSN to corem
Clutch issues
I have a 2012 Ram 3500 with a manual trans. It has tuner and loads more power than needed. I am going to need to replace clutch soon. What brands do you suggest? I have found a 13 inch dual disk not sure how that will go. Any help would be good. Thanks
Old 08-02-2015, 09:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Clutch issues
Which trans. do you have?
The 13 in. clutch goes on a 6 speed trans.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-03-2015, 11:41 AM
Re: Clutch issues
Yes I have Six speed. I have found 13 inch clutches at good prices. Not sure if that will be the best fit.
Old 08-03-2015, 05:24 PM
AF - Advisor
Re: Clutch issues
My single disc kevlar/ceramic w/3400# pressure plate holds good but I don't pull anything with mine.
