Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-31-2015, 01:24 AM
cliffwork cliffwork is offline
99 Saturn wont crank
99 Saturn SL2 will turn over but not crank. No fire to the plugs,,,,,,,change out the crankshaft positioning sensor, removed and cleaned ignitions module and coil pack, still wont crank and still no fire to the plugs
Old 07-31-2015, 08:47 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 99 Saturn wont crank
have you checked to see if it has any codes stored?
Old 07-31-2015, 06:45 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
I think what you meant to say is that the engine turns over, but won't start (start as in stay running). If the engine [crankshaft] won't turn over at all then you definitely won't have any spark because the crankshaft position sensor is not detecting any crankshaft movement.
If the engine is not turning over at all then you need to find out why which requires a different diagnostic approach.
I would first remove and reattach the battery terminals to ensure a good clean connection is established. A bad connection there can and will cause weird electrical anomalies on the S-Series cars. If grease has been applied to the battery terminal/cable ends then I'd recommend cleaning it off. It does more harm than good on side terminal batteries because it hinders the small connection (dielectric grease is an insulator). Check the battery cables and all grounding points if that checks out fine.
If the engine is turning over but not starting, how did you determine that you're not getting any spark?
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
