Old 07-30-2015, 10:57 AM
robean218 robean218 is offline
2002-Smoke coming from reservoir
Hello...My coolant light comes on..I checked the reservoir and it is empty. Added coolant and a week later, it is empty again. Today, I added to the reservoir and let the car run. Smoke started coming from the reservoir. What could cause this?
Old 07-30-2015, 12:41 PM
Tech II Tech II is offline
Re: 2002-Smoke coming from reservoir
Do you have any white smoke coming from your tail pipe, especially on startup? Does the engine initially misfire on startup?
Scanned for codes?
I assume this is a 4 cyl, 2.4 engine?
You obviously have a leak, and topping off the coolant, can only complicate the problem....if it is an external leak, it should be fixed...if you continue to drive it, causing the vehicle to overheat, they you could create more serious problems, like a head gasket problem....
The Following User Says Thank You to Tech II For This Useful Post:
robean218 (07-30-2015)
Old 07-30-2015, 12:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Check you oil level and condition. If it's over filled and/or milky colored, you have coolant in the oil. IF there is a fill cap on the valve cover, you can look inside for the milky color also.
Old 07-30-2015, 01:05 PM
4 cylinder, 2.4 engine and no smoke coming from tailpipe. checked oil and color and levels are good. The thing of it is that we checked the ground for leaks and the first time it was but I haven't drove the car in 2 days and nothing on the ground but the reservoir was empty again.
Old 07-30-2015, 01:10 PM
Old 07-30-2015, 01:11 PM
gmtech1's Avatar
Maybe inside the car? Heater core? You need to pressure test the system and inspect it.
The Following User Says Thank You to gmtech1 For This Useful Post:
robean218 (07-31-2015)
Old 08-01-2015, 11:41 AM
Blue Bowtie's Avatar
Registered Offender
Or possibly a head gasket leaking into a chamber (not into an oil drainback). If one of the spark plugs is extremely clean, that would be an indication of coolant in that chamber.
Old 08-26-2015, 12:14 PM
rhandwor rhandwor is offline
Go to Advanced Auto or Auto Zone get a loaner pressure tester. Install it and put about 10 psi on the gauge and run the engine if gauge pulsates you have a blown head gasket.
The Following User Says Thank You to rhandwor For This Useful Post:
rkvons (08-27-2015)
Old 08-27-2015, 01:14 PM
rkvons's Avatar
rkvons rkvons is offline
Thanks. Another good suggestion for diagnosing issues.
