Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 07-29-2015, 02:48 AM
f4milytime f4milytime is offline
Fog Lights
Hi All, My driver side fog light isn't working. Is this a common problem. And Yes I checked the bulb. Lol
Old 07-29-2015, 07:08 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Fog Lights
Vehicle description would help. Usually a bulb or connection issue. Did you try swapping the bulbs side to side and see if they work?
Old 07-29-2015, 11:32 AM
Re: 2004 Aztek Fog Lights
My bad, its a 2004 Pontiac Aztec. I tried switching bulbs from the working side. I was wondering if it a common problem. Whats messed up is my wires look fine from what I can see.
Old 07-29-2015, 09:08 PM
Tech II Tech II is offline
Re: Fog Lights
Since one side works, the relay is ok......connectors in the harness are ok?
If you swapped bulbs, and the the driver's side still didn't work......attach a test light to the connector to the purple wire and ground the test light...if it lights, you have a bad ground....if it doesn't light, you have an open in the purple wire or a bad connection at Underhood Fuse block...
Old 07-30-2015, 02:40 AM
Re: Fog Lights
Thanks Guys, I'll be back to post my findings.
