Old 07-27-2015, 10:16 PM
CMalfitani's Avatar
CMalfitani CMalfitani is offline
LC - 1/24 Toyota Celica Gr.B - Portugal Rally 1984
I just start a new model project.
This kit was created by a great friend, Luca Cavicchi, and it is an hnonor to build it. I hope I achieve a good result in the end.
I started by the Body Kit.
I clean the windons area, it is easy to do, there are feel points to work at this point.
I already open the hood air extractors:
And the front grille:
Doing this early work in the kit I noticed the good resin and casting quality presented by this resin kit.
Next Step is the engine hood alignment, some sand work is needed to adjust:
See you soon!
Thanks for watching!
Old 07-28-2015, 03:38 PM
puffyrs's Avatar
puffyrs puffyrs is offline
Re: LC - 1/24 Toyota Celica Gr.B - Portugal Rally 1984
Nice project.
The Following 2 Users Say Thank You to puffyrs For This Useful Post:
CMalfitani (08-04-2015)
Old 07-29-2015, 10:58 PM
CMalfitani's Avatar
Originally Posted by puffyrs View Post
Nice project.
Thanks a lot puffyrs!
One small step was achieved today
I almost finish the primary adjust of the bonnet. To adjust I sand the internal part of the bonnet and apply some heat with hair dryer to matching the bonnet with the front fenders.
Today I don't have to many time free to work on the Celica.
See you soon!
Carlos Malfitani.
Old 07-30-2015, 01:00 AM
stevenoble's Avatar
Excellent start, watching with interest...
Steve Noble
The Following 2 Users Say Thank You to stevenoble For This Useful Post:
Old 07-30-2015, 09:40 PM
CMalfitani's Avatar
Thanks a lot Steve! I hope not to disapoint you...
As I report yesterday, I finish the bonnet adjust, below attached the photo of inside of the bonnet after sand job.
The next step is the make holes on the some air bubbles in the resin on the trunk:
Roles already done:
I forget to buy a new putty to fill the air bubbles... My old one past away, I opened the can and it is totally dry....:
Tomorrow Is Friday, I will restart the work on Celica on next Monday...
Have a nice weekend!
Best Regards.
Carlos Malfitani.
Old 07-30-2015, 09:46 PM
afxracing's Avatar
afxracing afxracing is offline
Nice project, looking forward to more.
Motorsport Modeling
The Following 2 Users Say Thank You to afxracing For This Useful Post:
Old 07-30-2015, 11:26 PM
GTRfan01 GTRfan01 is offline
nice project!
i recently tried the superglue / talc putty and was presently surprised how well it worked for filling resin imperfections. maybe you should try this?
Old 07-31-2015, 04:51 AM
stevenoble's Avatar
Originally Posted by GTRfan01 View Post
I recently tried the superglue / talc putty and was presently surprised how well it worked for filling resin imperfections. maybe you should try this?
I can second this method, it works great and gives an excellent finish. Nice work cleaning up the hood
Steve Noble
Old 08-03-2015, 10:06 PM
CMalfitani's Avatar
Hello Everyone!
First of all my thanks to GTRfan01 and Stevenoble for the Tip! I try a mix of CA Glue + resin powder obtained from the model sanding process to fill the bubbles of the hood flips. Amazing technics!
Another little progress achieved today:
I fill with Bondo the sanding scratches on the trunk and hood exhaust holes, to posteriorly sand with a fine sandpaper (600):
I am sand and prepare the underbody too, removing excess of resing and molding marks (easy to remove due to high quality of resin and casting process.
See you tomorrow!
Carlos Malfitani.
Old 08-04-2015, 10:42 PM
CMalfitani's Avatar
Today I almost no have any improvent, For a good reason, two new rally kits, from the Rally Legend Walter Rohrl just arrive on my hands.
Kadett C GTE from Arena Modelli and Ascona A from Scale Production. Two relevant 70's rally cars from Opel.
By now these Opels come beck to the box, let's go back to the Celica.
Today I wash all resin parts with water and soap, to remove dthe release agent.
The sanding work on the underbody is on going... I hope to asseble the hood flips until the end of this week...
Thanks for watching.
See you soon!
Carlos Malfitani.
Old 08-04-2015, 11:28 PM
Cookster007's Avatar
Cookster007 Cookster007 is offline
Keen to keep watching progress on this build. Thanks for the tips.
Cheers,
Anthony
The Following 2 Users Say Thank You to Cookster007 For This Useful Post:
CMalfitani (08-05-2015)
Old 08-05-2015, 10:37 PM
CMalfitani's Avatar
Hello Everyone,
One more little step on the Celica Build
Today I applied primer to the Engine Bonnet and Engine Bonnet Splits to have a better idea of the points to correct before the split assembly to the bonnet.
The underbody sand work is on going.
Tomorrow, I hope to assembled at least one side of the splits on the bonnet.
Thank for watching!
See you soon!
Carlos Malfitani.
Old 08-06-2015, 11:16 PM
CMalfitani's Avatar
Another late update (It's already 00:10 AM in Brazil)
In older projects I learned that the movable parts are critical. Then in this project I pay special attention to the door trunk and to the bonnet.
Today I almost finish the adjust of the door trunk to the body. Some micro point need to be fill on departure angle of the rear spoiler. Easy to do anyway.
I already applied the resin primer to the door trunk, to make the little points to correct more clearly.
The sand job of the underboy is almost done. Little point need to be sand yet.
I expect to finish the sand job on the underbody and finally fix the splits on the bonnet this weekend.
Monday and Tuesday is holiday in the city that I work, then I will made a new post only after the holiday.
See you soon!
Carlos Malfitani.
Old 08-20-2015, 10:31 PM
CMalfitani's Avatar
Hello everyone!
This week I prepare some resin parts, made and revise roles according to the assembly instrunctions (thanks for the detailed instructions Luca!)
I started the base surface coat application.
For the first time I use the Mr. Hobby (Gunze) resin Primer, i like the preliminar result.
This week a new model arrived the Opel Ascona 400 from Gass Model. Another great job of Luca, made before the Celica. Thanks for these magnificent models Luca, they became any rally collection much more representative!
See you soon!
Carlos Malfitani.
Old 08-21-2015, 09:28 AM
kh62 kh62 is offline
A good side for Pictures is
http://www.mat.fi/projects
Karl-Heinz
The Following User Says Thank You to kh62 For This Useful Post:
CMalfitani (08-21-2015)
