Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-26-2015, 07:24 PM
kawyboy kawyboy is offline
2001 dodge ram 1500 318 engine
Starts fine. Runs fine till warmed up. Then dies at idle and runs rough on gear till 1000 rpm.
Has only coded iac when unplugged.
But would idle with it unplugged. I replaced it.
Also got crank can code once while checking it
Thoughts?
Thanks
Old 09-06-2015, 11:57 PM
kilmer01 kilmer01 is offline
Re: 2001 dodge ram 1500 318 engine
Thoughts?
Thanks
Im having a issue with mine also. My transmission went out and guess binded up. And now it will just turn over and not start. Its getting no fire to the distributor or nothing. Anyone know if the 2001 ram 1500 2wd has a saftey cut off when the trans goes out. I know if the three prong connector is unplugged it wont let the starter turn over either. But i was doing research on the not sraying started part and a simple fuse for the door locks can affect the powertrain might wanna try changing that fuse its good to change fuses every few years cause they wear out from the power current going threw them.
Old 09-07-2015, 05:01 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
If the Check Engine light is on, get it scanned.
Most chain type auto parts stores do free scans.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
