Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-26-2015, 09:37 AM
Lady clone Lady clone is offline
Charging issues
Hi. I recently changed my alternator on my 97 police engine. Most of those take a 175 amp alt, but I was told because I didn't have all the extra stuff that police use, I didn't need one that big. I bought the 135 amp. Now I'm having issues with my battery charging, and it's a brand new battery. I had a test done, and the alternator is reading 13.8, but I'm still having issues. Could it be that I do need the 175? I've checked the connections and they all seem to be good. Please help?
Old 07-26-2015, 10:16 AM
aleekat aleekat is offline
Re: Charging issues
13.8 at idle? What's the charging rate with all accessories on? And rate with rpms reved?
Did the place that sold you the alternator just not have a the 175 and wanted to sell an alternator?
http://www.aa1car.com/library/charging_checks.htm
Post back, that's what makes Forums Work.
Old 07-27-2015, 03:23 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Charging issues
If your electrical system is running 13.8v when the engine is on, then your system is charging. Check your battery.
The CVPI used the 135 amp alternator up through 2003, then switched to 190/200 amp clutched pulley Mitsubishi alternators. While the 175 was an available upgrade for your year, the 135 should be sufficient.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
