Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-23-2015, 09:40 PM
mcarthen mcarthen is offline
ignition problem
my 2001 chevy impala keeps blowing ignition fuses in the fuse box under the hood. i turn the switch and the fuse will blow. it use to just blow on occasion but now as soon as i turn the switch it blows so now the car won't crank at all. had the plugs and wires done and also have a new starter and alternator installed and a new battery. only one fuse is blowing (15A)
Old 07-24-2015, 09:37 AM
Tech II Tech II is offline
Re: ignition problem
What is the exact fuse ? Name? Number?
The Following User Says Thank You to Tech II For This Useful Post:
mcarthen (07-25-2015)
Old 07-25-2015, 11:51 AM
It is in the lower box and is a 15 amp fuse that says fuel inj ( i guess it's short for injection).
Old 07-25-2015, 12:45 PM
My fault....should have asked which engine size...3.1, 3.4, 3.5, or 3.8L....
This is for a 3.8.....If the fuse blows as soon as you turn the ignition on, disconnect all injectors.....now turn the key on...if it still blows, you have a wiring problem before the injectors...follow the harness to look for chafing anywhere....
If it doesn't blow, turn key off, now attach one injector....turn key on and see if the fuse blows...if it doesn't, then turn key off, and attach another and turn key on again....do this until you find the bad injector...
If this is a 3.1/3.4, mice are known for making a nest under the upper plenum, and eating the insulation of the wires going to the injectors, and causing them to short out....
Old 07-25-2015, 04:00 PM
I should have said also but it is a 3.8L and also where do I disconnect this wiring harness to perform this test...
Thank you
Old 07-25-2015, 04:12 PM
are the injector plugs on top of the motor along side the intake?
Old 07-25-2015, 09:44 PM
On a 3.8, remove the plastic engine cover....then follow the fuel lines to the fuel rail that goes around the upper plenum....you will see the 6 harnesses going to the injectors in the fuel rail....
Old 07-25-2015, 10:44 PM
ok I know the harness your talking about it has six plugs one on each injector i will try it tomorrow evening and let you know what happens
Old 07-25-2015, 10:48 PM
i know the harness I will do the test tomorrow and let you know the results
Old 07-27-2015, 05:38 PM
j cAT j cAT is offline
rather than remove the injector plug to the injector , follow the wiring back to the fuse box look for damaged wire from the engine . since you had this problem before and the engine ran good the injectors are fine it is a bad feed wire from the fuse to the engine where the wires break out to all the injectors. as soon as the key is to on NO CRANKING power is then to all the injectors... PCM makes the ground connection to turn on the injectors so that is not the problem.
Old 07-28-2015, 11:22 AM
jcat, didn't I say that?
Old 07-28-2015, 01:40 PM
this is what I saw you said "If the fuse blows as soon as you turn the ignition on, disconnect all injectors " this is why I said , do not disconnect the injectors ,just follow the wires back from the injectors to the fuse box first .. see whats broke.. he was going to see what injector was blowing the fuse , from his going to test this out remark by removing the injector feed wires. many novices will break the injector connectors .
Old 07-28-2015, 08:37 PM
"If the fuse blows as soon as you turn the ignition on, disconnect all injectors.....now turn the key on...if it still blows, you have a wiring problem before the injectors...follow the harness to look for chafing anywhere...."
By doing this you verify if it's the injectors or the harness.....but you are right about the injector connectors....some are tricky to disengage....
Old 07-30-2015, 02:21 PM
The engine is turning over but will not crank outside now looking for cracked and worn out wiring.
Old 07-30-2015, 08:22 PM
Sending the car to a service center, to many wires for me to trace and look at.
