Old 07-21-2015, 08:03 AM
gtbreps_2 gtbreps_2 is offline
2004 1500 Temperature Control
I own a 2004 Silverado 1500. Nearly every time I drive, I loose temperature control on the driver's side after about 15 minutes of running the engine. The passenger's side seems to be working fine. I'm not sure if it is a bad rheostat on the driver's side or a bigger issue. Any suggestions to diagnose and address this?
Old 07-23-2015, 09:49 AM
j cAT j cAT is offline
Re: 2004 1500 Temperature Control
temp control is a stepper motor issue most times. this moves the temp door to change air vent temps. with your vehicle you have 2 of these driver and passenger side.
on my silverado I found that the temp door stepper motor was sticking due to it binding on the vent housing so I installed washers very small to give the shaft a little space so it moves with no binding. IT could also be it is a bad temp door assy since it is over 10yrs old now ..
The Following User Says Thank You to j cAT For This Useful Post:
gtbreps_2 (07-23-2015)
Old 07-23-2015, 10:38 AM
Thanks for the suggestion. Gave me some ideas to research. It appears that it is a blend door actuator. I have found multiple reports of the same issue all being resolved by replacing that actuator.
Old 07-23-2015, 07:47 PM
post back how you made out.
Old 07-24-2015, 04:38 PM
Thumbs up Re: 2004 1500 Temperature Control
So far I have driven 3 times since replacing. So far I haven't had any issues. Seems to have fixed the problem.
Old 01-31-2016, 12:20 PM
yakkk yakkk is offline
Hey I've got the same issue - I planeed to replace the driver's side actuator. One question, when installing the new part, do I align the door shaft to the actuator or align the actuator to the door shaft?
Old 01-31-2016, 04:39 PM
you do not move the new stepper motor part or you break it.
you put it in that same as the old removed. move the vent door key.
yakkk (02-01-2016)
