Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 07-20-2015, 10:01 PM
Tandreoli Tandreoli is offline
Rear rotor and brake system
Rear rotor is moving around and can pull straight off
Old 07-21-2015, 12:02 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Rear rotor and brake system
Do you have a question? Are there an missing wheel studs? Does it only move when the brake caliper has been removed?
-Rod
Old 07-21-2015, 12:41 AM
Not sure why it's moving around no lug nuts missing it moves when the caliper is on
Old 07-21-2015, 12:42 AM
No missing studs either
Old 07-21-2015, 12:55 AM
Wondering if it's the hub
Old 07-21-2015, 07:37 AM
shorod's Avatar
SHO No Mo
If it's a 2002 or newer it could be the hub, although if the hub, the brake caliper and caliper mounting bracket would also be moving around with the rotor. Also if it's the hub, the unit would move around with the wheel installed as well, making it pretty difficult to drive straight, and certainly it would not be safe to drive.
-Rod
Old 07-21-2015, 08:30 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
is it loose with the wheel on? if you can't get to it with wheel on see if you can thread a couple of the lug nuts back on all the way then try it. they use the wheel to hold the rotor tight against the hub. if its still loose put wheel on and try rocking it top to bottom and see if you feel any movement
