Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 07-20-2015, 08:41 PM
Chris2007 Chris2007 is offline
is this much engine movement normal?
https://www.youtube.com/watch?v=XZx1lTV9No4
yes you can see the engine moving, especially when the gas pedal is applied.
For some time now there's been a roughness, a slight growling/gurgling (exhaust related maybe?) when accelerating. Engine seems to hesitate a bit sometimes when accelerating, particularly when you're coasting for a bit, then reapply gas, and also when you shift from park and just let it roll.
I realize cars weren't made to receive acceleration with the brake is applied, but that seemed a bit excessive to me.
2002 Civic EX, 66,700 miles. Mom's little buggy (she's almost 83 and perhaps a little more lead footed then is good for her!).
Old 07-20-2015, 11:59 PM
MikeCStig MikeCStig is offline
Re: is this much engine movement normal?
It doesn't seem normal. That first change from park to reverse seemed a bit harsh, then that flexing with the brake applied revving the engine seems a bit odd too. A little bit of flex is normal, but that seems like more than normal.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 07-21-2015, 08:26 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
i would say your rear mount/torque strap by firewall is bad or wearing out for the movement. it also flexes your exhaust quite a lot and may leak to a crack in the pipe making it louder. there may also be another center mount by radiator thats worn out, not sure if that car uses 2 or 1 to keep engine from rocking when shifted into gear
Old 03-31-2020, 07:39 PM
JimmyCreedog JimmyCreedog is offline
It looks a little excessive to me. Luckily, engine mounts or even mount inserts are pretty cheap. The expensive part is getting them installed, it's not a fun job.
2004 Honda Civic 2 Door, Nighthawk Black Metallic
