Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-18-2015, 02:55 PM
cshults's Avatar
cshults cshults is offline
Bypass Hose
Hi all, I'm going to be replacing my radiator, upper and lower hoses. While shopping for the parts on RockAuto, a 3rd hose was shown called a "Bypass" hose, part# ACDelco 14155S. I'm not sure what this is for, where it's located, what it connects, and if I should be changing it out with the upper and lower while I'm at it.
Any help would be appreciated.
Thanks,
Chris
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 07-18-2015, 03:59 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Bypass Hose
On cars so equipped the bypass hose usually connects to a small port on the water pump and will allow the coolant to bypass the heater core if the coolant level drops too low.
I'd go ahead and replace it if you never have. Chances are it is worn and brittle at this point.
Old 07-18-2015, 05:54 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Bypass Hose
Yep, it runs from the water pump to the intake manifold just in front of the EGR valve.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 07-20-2015, 02:38 PM
cshults's Avatar
Re: Bypass Hose
Thanks, guys!
Chris S.
1992 Beretta GTZ
