Old 07-17-2015, 06:55 AM
rickisrad rickisrad is offline
AC Compressor only works when jumped.
2004 GTP. This ac is kicking my a$$. I have recently replaced the condenser, drier, compressor......
My issue is that my compressor only works when jumped. I checked the relay and 10 amp fuse located in the engine bay fuse box and both seem fine. I replaced the pressure switch and put a new pressure switch connector on it. I got it to take a full charge by jumping the compressor. It blows very cold when jumped. The outside temperature on the dash is reading correctly. Any suggestions???? I have limited knowledge on electrical diagnostics so any help would be appreciated.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 07-17-2015, 08:31 AM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Compressor only works when jumped.
With a/c commanded on- gently pull the a/c relay in and out- does it click each pull? If so, problem is between relay socket and compressor, or bad relay (swap it with horn relay).
If not, then problem is that computer is not allowing compressor to come on from a bad input or sensor. The pressure sensor you replaced should have been the 3 wire pressure transducer- were all three wires good? one is ground, one is 5 volt, one is reference voltage corresponding to refrigerant pressure- use your volt meter with sensor plugged in to monitor.
A Tech II scan tool would really help- other things like a bad engine temp sensor reading really hot will not allow compressor to engage- does your car have other issues?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-17-2015, 08:45 AM
No other issues. I replaced the relay with the horn relay and it did not work. Is there a way to test the sensors? On the oe connector it had a red wire with black stripe, a white wire and a black wire. The new one had a blue wire, grey wire and a black wire. I connected black/ black, red/ blue and white/grey. Thanks for the help.
Old 07-17-2015, 09:16 AM
brcidd's Avatar
The new sensor should have just plugged into your oem connector- why are you splicing? You may have gotten the wrong part. I would have tested sensor first- as described above.......
You may be wired wrong as well- you could fry the PCM (or at least make it unhappy) doing this wrong.
Where did you tap into compressor circuit to "jump" it?
'99 GMC Yukon
Old 07-17-2015, 10:53 AM
I replaced the switch and connector. I replaced the switch first and then the connector. They sell a pigtail connector. I removed the relay and used a wire in between the top two pins.
Old 07-17-2015, 11:20 AM
Tech II Tech II is offline
Ok, I assume you have enough refrigerant in the system.....
The pressure sensor has 3 wires.....black is low reference....grey is 5.0 volts.....and red w/black stripe is you signal voltage.......since the new connector had different colored wires, did you reference the colors with the actual positions of the connectors of the old harness connector...black is #1, grey is #2, and the r/b was #3 terminal...
What you can do is check the red/black line.......for the AC to start, there should be around 1.5 volts on the signal line....if too high, 5.0 volts or too low, under 1.0 volts, the PCM will not ground the relay....have also seen bad connections at the UBEC(what the relay plugs into).........
Old 07-17-2015, 11:22 AM
brcidd's Avatar
Since the colors differ on the connector- then you ave to be sure the positions of the wires were maintained and wired in accordingly- hopefully you did that okay--- what made you decide to replace the pressure transducer?
Good that you jumped at the relay- much easier that way- no pin probing and the ground is always proved good as well.
Time for a TechII to tell you what input is unhappy...
'99 GMC Yukon
Old 07-18-2015, 06:45 AM
I did have the connector wired wrong and rewired it :o .Unfortunately it still does not work. I will check the pressures again to see what they are. I could have used the air last night sitting in traffic for two hours at the Paisley concert
Old 07-18-2015, 11:25 AM
Ok I have some pressure readings.
when the compressor is not running the Low side reads 110psi and rising the high side reads 150 psi.
With the compressor jumped at the relay and running the low side reads 45psi and the high side reads 250psi.
It is about 90 degrees outside.
Do any of these readings mean anything to you guys? Unfortunately i do not have a tech 2 scanner just a plain old obd2 and my aeroforce gauge. I will have to take it to RadAir if i need to get it scanned. Thanks
Old 07-18-2015, 01:55 PM
brcidd's Avatar
You might try unhooking battery for 10 minutes - If there is an a/c code set- it may reset. Worth a try.
'99 GMC Yukon
Old 07-18-2015, 03:53 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Old 07-18-2015, 06:20 PM
Would a code not allow it to run? Going by that chart it looks like the pressures are almost dead on, maybe low side could be higher but I think the compressor should be running where its at. I put about 37 ounces of freon so it should be ok. The pressure switch shouldnt be the issue because the pressures are ok.
Do the pressures matter when the compressor is off???
Maybe I should replace or check the other temperature sensor in the air duct??
Old 07-18-2015, 07:54 PM
Stealthee's Avatar
Is your temp sensor reading properly? When they freak out and say it is 40 when it is really 90 the compressor won't run because it thinks it knows what you want. That's one of the reasons I hate digital climate. Like one time I was coming home one evening and it was a really cool 55* so I wanted a little heat. I set the heat to 75 and the car still blew cool air because it thought I didn't really want heat.
Old 07-18-2015, 08:38 PM
Yeah the temp on the DIC is accurate. Today it read 95 and it sure as heck felt like it. I think there is another sensor for the interior or evaporator temp somewhere. I may have to break down and get it diagnosed one of these days.
Old 07-18-2015, 08:56 PM
brcidd's Avatar
There is no other sensor- the system has a variable stroke compressor that adjust the refrigerant flow- so no evap sensor needed. A code could have been set when you had it wired wrong- or unplugged- and can only be reset by a scan tool or perhaps a battery unhook- worth a try in my opinion. Sure the pressures are fine on your gages- but what does the computer see? that is what the high side transducer is producing.
A Tech II scan tool will tell you what input is amiss- and whether or not it is commanding the relay and/or relay driver on or off.
If you are friends with a dealership- ask them to let you borrow one for a minute- sure would get you to your answer a lot faster than guessing.
'99 GMC Yukon
