Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-12-2015, 10:54 PM
shyann_62801 shyann_62801 is offline
99 century coolant light blinking
I have replaced radiator and thermastat.awhile back.. I checked and there is antifreeze in the radiator and the resevor. I dont drive it unless i really have to. and not to far,lots more work to do on it.But the coolant light started blinking the other day. Temperature gauge inside is ok. What could this be? what should I do?- Still havent got the blower working,heater/ac/defrost. still looking to see if i can get help with that.
Old 07-13-2015, 10:01 AM
Tech II Tech II is offline
Re: 99 century coolant light blinking
Did you ever fix your leak?
Is the light "flashing" the low coolant light? They don't usually flash, they just come on solid....
You replaced the radiator? Is the low coolant sensor in your radiator? Is it hooked up?
Ever check for power at the blower motor with a test light?
You should stick with one thread....this is your third one....
Old 07-14-2015, 11:29 AM
Sorry for different threads I thought I had to do that for different subjects. sorry . I got the bypass pipe thing fix of the leak it lasted for a month and I just notice it is leaking again in the same spot. The coolant light dont stay on it just blinks. Dont know if the coolant sensor in new radiator if they hooked it up or not. When I got the car back from putting new radiator and thermastat in the light coolant like never was blinking. then I had the leak at the bypass pipe then blower problem(cant find anyone with a test light to test the blower yet-still looking.
Old 07-14-2015, 11:42 AM
Is the light the low coolant light or the temp light that is flashing?
Old 07-14-2015, 12:56 PM
low coolant light is blinking
Old 07-14-2015, 01:47 PM
If your radiator is full....look at your radiator....passenger side...approx the same height of your headlights....you will see a harness going to a "square" sensor in the radiator?...disconnect it....does the light go out?
