Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-12-2015, 12:45 AM
landscaperdude landscaperdude is offline
1993 dodge 350 key does nothing
93 dodge 1 ton 4wd. after sitting for 8 days unused in rainy weather, it now wont start. The "wait to start" light and others on dash don't come on. with key in run position, the only thing that works is the windows(dome and headlights work, and don't dim when working windows). turn signals don't work. really, nothing happens when key is turned. do I change the obvious ignition switch, or is there anything else to check first. never gave hint of a problem before.
Old 07-13-2015, 09:28 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1993 dodge 350 key does nothing
I'd do some basics, clean the battery connections and check the battery ground at the engine block.
How many volts on the battery?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
