Old 07-11-2015, 09:28 PM
chuck34108 chuck34108 is offline
2005 Chrysler Pacifica,
I have a 2005 Chrysler Pacifica with 170,000 miles.
This car has many issues. We replaced the transmission in March with a rebuilt one we also replaced the plugs and wires at around the same time. Soon after that we were having trouble with it starting on occasion and it has been diagnosed as a fuel pump going bad. We have to turn the key to on 5 or 6 times in order to prime the pump. Then it may start or it may take a second cranking of the engine for it to start. Now, it has gotten to where the battery will try to crank it a few times before you hear the starter clicking. At first this was happening overnight. We would jump the car and it would be fine getting me to and from work but the last few times I drove it, it had to be jumped every time I try to start it. I've taken the car back to different auto parts stores to have the battery checked and they all find that the battery needs to be charged but otherwise tests as good and the alternator and starter are both testing good. Even after driving the car for an hour before parking it, i had to get a jump start in the morning. I've made sure that the radio, lights and A/C are all off before shutting off the car.
I understand the issues with the fuel pump but don't understand what is happening to the battery. Could priming the fuel pump really be draining the battery that much?
The Following User Says Thank You to chuck34108 For This Useful Post:
Roger_Simota (09-02-2015)
Old 07-12-2015, 05:11 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 2005 Chrysler Pacifica,
try unhooking the battery when you park the car for the night. if you hook it back up next time you go to start it and it starts then there is a drain in the car draining the battery. if it doesn't start the battery is bad and needs to be replaced
Tags
battery , chrysler , pacifica
