2006 Ram 3500 Diesel ==HARD START==
I have a 2006 Dodge Ram 3500 with cummins engine, about a week ago it started to get, hard to start, hot or cold, it will crank for about 15-20 seconds and start, once started it runs good, help please
Re: 2006 Ram 3500 Diesel ==HARD START==
Is the Check Engine light on?
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
The engine light is not on, nor smog when started either, thanks
Did you come up with a solution?
Yes it was the injectors #2 and #5, losing pressure
| The Following User Says Thank You to Elfego For This Useful Post: | ||
Chris Stewart (03-05-2016)
