Old 07-06-2015, 07:47 PM
kassie78 kassie78 is offline
Climate Control Module
Hello, I'm wondering if there is a 100% way to check and see if my climate control module is bad. No lights work on it, it doesn't turn on the ac or the blower. I took it off it all seems to be decent from what I can tell. But its just not working.
Thanks in advance
Old 07-14-2015, 03:09 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Climate Control Module
Not sure these are conlusive but I would start by removing and inspecting the connector at the back of the panel. The contacts often overheat, melting the connector and forcing the contacts apart opening the circuit
Disconnect the negative battery cable for 5 minutes. The panel contains a microprocessor/controller that can get froggy. This may reset it.
Verify you're getting 12vdc at pin 10 (black/orange wire) at the connector with ignition switch at on.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
