Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 07-06-2015, 12:20 AM
Brentivy Brentivy is offline
need help with engine install
Is there anything extra i need to do to fit a 1993 4.3L Vortec engine into a 1995 GMC Jimmy? What is the difference between the two engines, and will i have complications?
Old 07-09-2015, 01:04 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: need help with engine install
There will be minimal, if any, difference between the engines. I believe 1992 was the first year for the 4.3 having a balance shaft. You should be able to simply swap the long block.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-09-2015, 01:21 AM
Do you know if the reluctor ring for the crankshaft position sensor on the 95 is the same as the 96. Cant find a 95 anywhere but found a 96.
Old 07-09-2015, 12:13 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
96 will be a obd II setup. 95 will be a obd 1 1/2. looks like there are some difference in the block so it may not swap over like you want. looks like there are used engines for sale in your state for 95 that will drop right in assuming its the s10/s15 style. you can see whats out there on car-part.com and select your state and what engine yours is
Old 07-09-2015, 12:50 PM
Thank you.
