Old 07-04-2015, 08:40 AM
rfloch4 rfloch4 is offline
Air conditioner blower
The stock AC fan on my '90Blazer is weak. Am thinking an in-line step-up (around 4-6 volts) transformer, would increase performance. Meaning more RPMs=more COLD air. Here in the HOT, globally warming San Joaquin Valley. I'll take, NO REPLY, as an affirmative.
Last edited by rfloch4; 07-04-2015 at 10:43 AM. Reason: Found the REAL reason. Gunk(leaves) in the blower box
Old 07-04-2015, 09:17 AM
Blue Bowtie's Avatar
Registered Offender
Re: Air conditioner blower
Welcome Aboard!
You could do that, but you would likely be disappointed. Unless you have some kind of very special Blazer, a transformer is unlikely to help, let alone even work (except to blow fuses). Transformers can operate very effectively on AC. On DC, they act as a dead short once saturated (about 60-150 mS). If you have installed an inverter to power the AC fan on your Blazer, a transformer could work, but it would be just as easy to increase the output frequency of the inverter to increase speed.
Chances are that's not the case, however.
If the fan is actually running slowly (low RPM) it is likely that the fan motor brushes and commutator are finally wearing after 25 years of service. If the fan motor runs at a reasonable speed but air flow is insufficient, that might be a problem with debris on the evaporator core face. After 25 years, that is not uncommon either. Perform a little diagnosis to determine which (if not both) conditions might exist on your truck.
Or, you could install a transformer.
The Following 2 Users Say Thank You to Blue Bowtie For This Useful Post:
rfloch4 (07-04-2015)
